Posted by Bob M on December 09, 2008 at 10:49:07 from (151.190.254.108):
In Reply to: Re: Yo Jim Bob M posted by John T on December 09, 2008 at 10:19:10:
John T - You can demonstrate the effect of current draw vs starter RPM on a slow-cranking tractor like a JD A or G. Simply turn on the lights then hit the starter. You will see the lights alternately brighten and dim in time with the starter speed variations. (Or with the tractor cranking engage the clutch with the tractor in gear. The lights will nearly go out when the starter stops turning....at least until smoke escapes from the starter...)
I'm planning to attend the 2009 Expo. Only kicker is my last unmarried daughter is getting married the following weekend. So it's uncertain whether the "Divine Mrs M" will be joining me at Canandaigua for this show.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
