Posted by glennster on December 09, 2008 at 13:21:03 from (76.222.57.166):
In Reply to: Farmall M Leak posted by TC2 on December 09, 2008 at 12:49:58:
prolly the oil seal behind the brake drum. you need to pull the cover and brake band, then take the center bolt out of the shaft, thenpull the drum off. there is a seal in there. dont try and take any bolts off behind the cover, you need to work the seal out, then replace it. lot of guys put 2 seals in with gun grease packed around the inside of the outer seal. if its got a clutch on the left side housing, it prolly has an aftermarket m+w sort of live pto set up. we use ta call them a baling clutch, it will have oil seals in there too.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
