Re: Static Friction v. Sliding Friction
Posted by hughB on December 09, 2008 at 15:01:02 from (66.82.162.11):
In Reply to: Re: Static Friction v. Sliding Friction posted by Bob on December 09, 2008 at 13:50:37:
I may be all wet on this and stand to be corrected but I was told many years ago that going to a "higher gear" caused power to be applied to both wheels thus eliminating one wheel spinning when you loose traction. I copied the following from a website. "Differential: (A) Standard – gear assembly on the drive axle that
permits the wheels to turn at different
speeds. (B) No-Slip or Limited-Slip –
will not permit one wheel to spin
while the other is motionless, such as
when a truck is stuck in snow or
mud. Torque is transmitted to both
wheels of the driving axle."
