Re: Gas tank dent on 130
Posted by Gene Bender on December 09, 2008 at 16:06:31 from (67.55.226.167):
In Reply to: Gas tank dent on 130 posted by EZ on December 08, 2008 at 20:06:20:
A dent like that will be hard to remove just go the Bondo route. That metal is good stuff and that size and the place aint easy Bondo.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
