Re: Gas tank dent on 130
Posted by bc on December 10, 2008 at 09:24:45 from (69.149.215.139):
In Reply to: Re: Gas tank dent on 130 posted by Hugh MacKay on December 10, 2008 at 06:05:42:
Hugh or anyone, got any ideas for rigging up a homemade vacuum pump? Apply that to a suction cup and I could come up with multiple uses. Don't suppose a shop vacuum cleaner hose would pull out a dent. For a larger dent, could remove the plunger handle and put the vacuum hose over the rubber part.
Wonder if the dry ice hail method would work. Warm up the metal or wait for a hot day, then spray the area down with a water bottle, and then lay a piece of dry ice wrapped up in a rag on the dent to pop it out. Haven't tried it yet but I have a few hail dents I'd like to. Dry ice isn't all that cheap anymore though.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
