Re: 47 farmall h
Posted by rustyfarmall on December 10, 2008 at 09:35:46 from (209.152.78.9):
In Reply to: 47 farmall h posted by El Toro on December 10, 2008 at 08:31:14:
usetabesteve said: (quoted from post at 09:44:53 12/10/08) That pipe screws into the muffler, on threads cut into the cast manifold.
If the manifold is ok other wise you can get a tap or thread chaser and try to clean out those threads before you change the manifold.
The pipe threads into the manifold, not the muffler, but I'm sure that is what you meant to say?
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
