Re: Static Friction v. Sliding Friction
Posted by Janicholson on December 10, 2008 at 10:59:12 from (199.17.6.128):
In Reply to: Re: Static Friction v. Sliding Friction posted by hughB on December 09, 2008 at 15:02:14:
With respect, you are pretty damp.
The friction of a wheel which is not in spinning, but rolling in its motion on ice has hundreds of times more pulling power than when it is slipping melting a water layer under it.
Higher gears lower torque in a way that stays (more often) within this zone of not slipping. Differentials always put the same force into both tires. When one slips, the other pulls, but only as hard as the slipping tire.
The thing is just like hooking a 2X4 about 6 feet long to a pair of cement blocks, and pulling in the middle to drag them. If one gets on ice, it slides and the other stays behing. But the same force is still pulling on each, it is just much less force. JimN
