Re: 47 farmall h
Posted by GordoSD on December 10, 2008 at 15:45:10 from (66.115.200.140):
In Reply to: 47 farmall h posted by Doug st cloud mn on December 10, 2008 at 08:31:14:
You say, "part of the pipe" Is the bottom of the pipe still in the manifold? If so that old piece has to come out.
Remove the manifold. Lay it flat. Trim off any pipe outside the manifold 1/4 inch above the manifold Use your sawsall and cut it in two places. Go just barely into the threads Knock out the pieces. Use the 2 inch NPT tap to clean up the manifold threads. I've done half dozen, maximum 10 minute job.
Gordo
