Re: Changing Brakes on Farmall Super M
Posted by Brownie 450 on December 11, 2008 at 05:51:14 from (216.51.158.151):
In Reply to: Changing Brakes on Farmall Super M posted by Gary T. on December 11, 2008 at 02:04:05:
Did you thoroughly clean & take all the rust out of the brake casting[housing]? Are the splines on the brake shaft free of rust/dirt? Is there any binding when you pull the actuating bolt? These brakes are usually good if they are clean. I assume the surfaces where the fiber discs contact are smooth.
