Presuming the metal friction surfaces are smooth (ie. not rusty or pitted), disc brake locking up is the result of excessive distance (wear) between the inner and outer non-moving friction surfaces. However it can also be caused excessive actuator plate ball ramp wear, slightly undersized actuating balls or wear (notching) of the brake shaft splines.
What’s happens is as the balls roll to the ends of the ramps they become wedged when the brake begins to take hold. Further movement causes the brake to "cam" and lock up. Backing the tractor unwedges the balls and releases the brake.
The ideal repair is new parts (inner housing, cover, actuating disc assembly). However you can probably accomplish the same thing by milling perhaps 0.10” off the cover mounting face - effectively decreasing the distance between the inner/outer friction surfaces.
Alternatively OEM Tractor Parts can rebuild Super series disc brakes - I don’t recall the cost however.
Incidentally from my personal experience the Farmall Super series disc brakes - with all internal parts within tolerance, clean (no oil!), and properly adjusted - work great…..better than the earlier band brakes IMHO.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
