Re: Q? for John T - field resistor ohms
Posted by Bob M on December 11, 2008 at 06:16:36 from (151.190.254.108):
In Reply to: Re: Q? for John T - field resistor ohms posted by Janicholson on December 11, 2008 at 05:26:03:
Thanks for the speedy response guys - that's the info I need!
Jim - I believe your power disipation is off by about factor of 20(!). Calculation:
Genny field resistance = 3 ohms (thanks John T!); field resistor = 3 ohms. Total resistance field circuit resistance is thus 6 ohms.
Assume the system voltage is 7.5. New using E = IR (rearranged to I = E/R) field current is:
I = 7.5 / 6 = 1.25 amps
Power dissipation across the series resistor (I squared R) then becomes:
1.25^2 x 3 = 4.9 watts(!)
Therefore 5 watt resistor will be more than adequate.
Bob M
