Re: Studs: to remove or not to remove.....
Posted by spiffy1 on December 11, 2008 at 08:05:40 from (70.41.137.72):
In Reply to: Studs: to remove or not to remove..... posted by spiffy1 on December 10, 2008 at 21:24:30:
rustred said: (reply to post at 01:12:41 12/11/08 )
The head gasket looks to be about standard thickness, but I've never before used anything but the ones with the metal layers on each side [and that's what came out of this tractor too].
Somehow just getting paranoid on the head; I knew they'd likely take .01-.020 to bring it flat, but while pulling the sleeves I got to thinking I may have underestimated the clearance needed. Especially if that head gasket is say .020 thinner than the metal sided ones. Yeah, I know I'm likely just paranoid.
The manifold on the other hand sits quite close to the block (589-D), with .010 or so already off the head; I may have to be creative here; maybe I could have it milled, and use the gasket for a pattern on a couple pieces of shim stock to put on each side. It might require a couple welds on hairline cracks (still debating and plan to have a welding shop advise whether they're better left alone or welded) so the shop may have some advice there, but if someone here does too all the better!
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
