Based on where the third brush is, voltage in the field circuit has to be close to the voltage at the A terminal. 5 to 6 volts seems like a good guess. Dividing that by 2.8 ohms gets about 2 amps. Multiply volts by amps and you have 10 to 12 watts.
Based on what resistors are easily obtained, I have suggested getting a pair of 5 ohm resistors rated for at least 10 watts. Connect them in parallel, giving 2.5 ohms and 20 watts. Leave the leads long enough that the resistors can be separated a bit from each other and the switch. Keep other wiring separated from them.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
