Re: Q? for John T - field resistor ohms
Posted by Jim Becker on December 12, 2008 at 07:03:28 from (71.252.139.51):
In Reply to: Q? for John T - field resistor ohms posted by Bob M on December 11, 2008 at 05:18:37:
For temporary use, just connect the generator field to the unused F terminal of the cut-out. That will give you low charge. Add a short jumper wire with an alligator clip to either terminal and clip the other end to a ground for high charge.
Better yet: Add the above mentioned jumper from F to F, remove the resistor from the switch. The switch will control charge rate normally.
