Chipped gear IH 340 hydraulic pump
Posted by chuckles on December 12, 2008 at 08:07:13 from (71.253.82.62):
I have a 340 with a Thompson 12 gpm transmission driven hydraulic pump. It had a leak around the mounting plate that I decided to fix. When I pulled the plate and the pump, I noticed that on of the teeth on the pump gear was chipped. I'm not sure whether I did it when I pulled the pump or it was that way. Regardless the 16 tooth gear part number 370949R1 is no longer available. They do still have a 15 tooth gear part number 373711R1, but I am not sure if that will work. Does anyone know? If not does anyone know where I can find a used one? or is it possible to have the tooth welded and re machined (about 1/2 of the tooth is missing)?
Thanks for the help
Chuck
