hello! thanks for the reply. my reverse more or less all of a sudden stopped going into gear if i could hold it in i sure would try your remedy. i noticed on my gears they may be worn but are still there but it seems like it should go in gear. as for you doing your clutch with the loader and backhoe it was easy depending on your mechanical ability i have been spinning wrenches for 25 years. anyway once you remove all the bolts and support the rear of the tractor it will slide along the front loader support with a jack i did mine in the dirt so i put a piece of diamond plate steel for the jack to roll on just take your time and be sure to place the jack on a good balance spot on the tractor. that was the only trouble i had. .... chris
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
