Re: IH 300 utility vs. farmall H
Posted by D Slater on December 12, 2008 at 11:09:42 from (71.164.59.133):
In Reply to: Re: IH 300 utility vs. farmall H posted by D Slater on December 12, 2008 at 04:56:27:
Failed to put in other post that governor throttle arms are different 300 compared to H. They can be switched from governor to governor or whole governors switched. If you use a H carburetor use the throttle shaft and housing for the H and one for 300 if using 300 carburetor. Slight difference in the length on them. Another thing to address is the air intake pipe size and choke rod if using the 300 carburetor.
