Posted by Janicholson on December 12, 2008 at 11:34:10 from (199.17.6.128):
In Reply to: 44' H posted by Triplerange on December 12, 2008 at 08:02:50:
If you want to, the L terminal can be the supply source for the light switch (probably now comming from the Amp Meter load side).
Be sure to remove the generator Field wire from the light switch, and from all connection to the generator Field, or F terminal on the VR. This is a grounding wire, and will interfere with Voltage regulator action. Your 4 position light switch will be OFF OFF,Dim Bright. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
