Re: 300 won't start
Posted by brent/pa on December 12, 2008 at 16:56:18 from (71.60.32.245):
In Reply to: Re: 300 won't start posted by LMack on December 12, 2008 at 15:29:08:
Thanks for the replies. Yes, the air cleaner is removed, and is sucking hard thru the carb. Thinking possibly a carb problem we swapped the carb with one from a 350 and still no success.
I pulled the fuel line off of the carb and it's got good supply. Also tried blowing into the carb thinking the float is stuck but can blow thru easily so the valve's open.
I've tried either (starting fluid) but it doesn't even try. Thus spark, compression, fuel but no bang.... other than a possible timing issue I'm lost.... Is the cam gear drive or chain drive?
