Posted by ScottyHOMEy on December 12, 2008 at 21:12:32 from (71.241.208.102):
In Reply to: Oil in Super A radiator posted by Joe McGonigle on December 12, 2008 at 19:57:57:
There's fewer possibilities this way than the other way around (anti-freeze showing up in oil).
Easiest, simplest and least critical is a head gasket giving out. Replacing it involves (naturally) removing the head, which you'd have to do anyway to check out the other possibilities, a crack in the head or the crankcase. Sometimes but not always, a bad head gasket will show up a leak across the two systems. In the absence of anything obvious, a crack in the head or block might take a more practiced eye.
Removing the head on an A is a pretty straightforward job that can be done with a basic socket set, but it would be good to have a service manual at hand before you get into it.
Today's Featured Article - History of the Nuffield Tractor: Part 2 - by Anthony West. In February 1953 production of the ETC T.V.O engine started, ready for the March 1953 press announcements. The new TVO engine had a number of improvements which resulted in a 10 per cent more power (43bhp as against 38 bhp on the earlier engine) and 10 per cent more fuel economy. Some of the improvements are listed below: Redesigned combustion chamber, improved spark plugs and positioning, plug size 14mm(earlier size 18mm).
... [Read Article]
Latest Ad:
[More Ads]
