Posted by Hugh MacKay on December 13, 2008 at 06:42:46 from (209.226.106.2):
In Reply to: Oil in Super A radiator posted by Joe McGonigle on December 12, 2008 at 19:57:57:
Joe: gene and Scotty have given you some very good advice, and like gene, I'm assuming you know very little of the past history.
To add to what has been already said, do you see any evidence of anti-freeze or coolant in the crankcase? Oil in the radiator will not have any adverse effect, however anti-freeze in the crankcase will. It will destroy the crank and rod bearings quite quickly, plus do significant damage to the crank. My guess is 95% of all cranks ever requiring turning and machining was brought on by anti-freeze in the crankcase.
Having said that, I'd drain both liquids, look them over very closely. Anti-freeze in oil will make it sticky when you rub it between your fingers. Oil alone should be quite slippery. If you find pure oil from crankcase, fill crank case and radiator with fresh clean liquids, carry on and watch both closely as you use the tractor. If your getting one way movement of liquid from crankcase to radiator, you should see bubbles in the radiator after tractor is warmed up. Then and only then I'd go looking for a cracked head, cracked block or bad head gasket.
On the other hand if you find coolant in the crankcase oil, you best get the wrenches out PDQ.
Today's Featured Article - History of the Nuffield Tractor: Part 2 - by Anthony West. In February 1953 production of the ETC T.V.O engine started, ready for the March 1953 press announcements. The new TVO engine had a number of improvements which resulted in a 10 per cent more power (43bhp as against 38 bhp on the earlier engine) and 10 per cent more fuel economy. Some of the improvements are listed below: Redesigned combustion chamber, improved spark plugs and positioning, plug size 14mm(earlier size 18mm).
... [Read Article]
Latest Ad:
[More Ads]
