OK so I spent today (finally got some good weather!) looking at the tractor and I believe my starter selenoid is bad. Even when I jump across the I and S terminals I get no power to the starter lead. I took it off and tested it with a small battery (8.2V RC Car battery) and I get 8.2V @ the I and the input when I connect it. If I jumper across the I and the S I still get 0 Volts to the starter side.
My next question is now where do I find a replacement? This is a Ford Selenoid? Can I bring it to Autozone and get a replacement or do I need to go to a Ford dealership (or a Ford tractor place)?
Thanks in advance! PS - I also removed all connections and cleaned them with a wire brush, the + and - battery terminals, the tractor ground, the push button to activate the starter (I removed it and tested it and it gets connection when depressed) as well as the back side of my ignition pull switch.
Unless my starter is bad too then with the new seleniod I should be good to go. Any way to test the starter without the selenoid?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
