I think there is some geometry different for the "major thrust" side.
For example, on the power stroke, there's a "ton" more load on the piston and so the direction it is travelling requires more thrust (supported by cylinder sidewall) support, and possibly a geometry change to the rod as well to encourage crank rotation in the normal direction.
New pistons that go into the latest 4-cylinder automotive engines have a completely different geometry from one side to the other in order to provide support where it is needed and take away drag where support is unneccessary.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
