Harvey: You have a Cub LoBoy and the serial number is 21969 the number you found on the steering box. Metal tag on steering box is the location of Cub serial numbers. I suspect Cub and Cub LoBoy share the same sequence of serial numbers. J stands for rockford clutch. All those numbers you see ending in Rxx are part numbers.
The engine will have a serial number, however I'm not familiar where it is on a Cub. You have to remember that Cub engine is quite unrelated to other IH engines. Most other IH engines have the engine serial number directly below number 1 plug on right side and that number is stamped on a machined flat surface. It is stamped, as opposed to cast letters or a tag.
Most other IH engines being overhead valve, places the plugs on the side, however Cub plugs are on top. Look for the machined flat surface anywhere on the block.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
