Re: 49 farmall c
Posted by LMack on December 13, 2008 at 16:31:17 from (208.61.26.208):
In Reply to: 49 farmall c posted by Dougie94 on December 13, 2008 at 15:02:05:
Sounds like a fuel problem and I agree that it must be running lean. If you have a Carter carburator, the adjustment screw is for high rpm. You should have set as instructed in the rebuild kit when you did the carburator rebuild. Fine adjustment has to be completed with the engin running. Try letting it out a little at high rpm and see if that helps. If your gasoline is old the carburator will not like it. If the adjustment does not help, try draining the carburator bowl and cleaning the sediment bowl. LMack
