For everyone that replied I do appreciate it! On the modifications for the sub-frame brackets on the front end I had to redrill two holes closer to the brackets and on the back of the sub-frame where it mounts to the rear axle housing, I had to cut the square tabs off and re-weld them so that the bolts on the brackets are out at the end of the square housing on the tractor. Hopefully this will work and let you know if everything bolts up! Also, on the front end I had to put 2" spacer blocks between the brackets and the tractor housing. Again, Thanks.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
