Re: More yet, H questions
Posted by ScottyHOMEy on December 13, 2008 at 18:37:22 from (71.241.208.102):
In Reply to: More yet, H questions posted by Farmallb on December 13, 2008 at 18:09:52:
It's all electrical, but you're talking about two different systems.
With a coil ignition, you need a battery and something to keep it charged, which could be either a genrator, usually 6V, or an alternator in the case of 12V. The ignition system relies on getting power to the coil from the tractor's electrical system.
With a magneto ignition you do not need a battery or anything to charge it to make it run. It's self-contained. Magneto tractors frequently do have batteries and generators or alternators, but those are there only for operating things like electric starters and light. The presence of battery and charging system has no effect whatever on a magneto igntion.
So having an alternator doesn't mean you should have a coil ignition. That's not to say that it's possible you have a coil-tye ignition and the coil is missing.
I apologize for not recalling your past posts, so I have no sense of your experience for what you're attempting just now, so if some of this seems too basic, it's not meant as an insult.
You may not have a coil because you have a magneto. In that case there's one set of ideas for solving the no-spark problem.
If you've got a coil and distributor, that's another set of solutions (with a little overlap).
Look back at the pictures Steve sent a few days ago. If what you have looks like the lower picture, with a round cap with room for five wires and a domed but rectangular cap on top with one wire, then you have a magneto.
If it does not look like that and looks more like the upper picture without the coil, you may simply be lacking the coil, the addition of which would be a good first step to getting a spark, but there likely will be other things to check and replace (points, condenser, plug wires and maybe some wiring on the tractor -- if the coil's gone, who knows what's left), all manageable.
Figure out which you have, and let us know and we can go from there.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
