Posted by CNKS on December 13, 2008 at 20:02:03 from (216.144.104.128):
In Reply to: Re: 460 gear clash posted by D Slater on December 13, 2008 at 19:44:36:
I have to have 2 inches (spec is 1 3/8) pedal travel to get 1/8-3/16 inches between the fingers and the release bearing. That is just enough to keep the bearing away from the fingers when clutch is engaged. It does sound as if something gets out of line when the rod is connected and the main clutch pushed in. But I don't know where. I attempted to eliminate any main clutch drag with the washers between the pressure plate cover and the flywheel. If there is drag, it didn't help. I know this is ridiculous, but I have split that tractor 4 times -- getting good at it, but it takes a lot of time with limited results each time.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
