Re: change 1947 Cub magneto to reg points and coil
Posted by john *.?-!.* cub owner on December 13, 2008 at 20:35:55 from (72.161.148.87):
In Reply to: change 1947 Cub magneto to reg points and coil posted by Frank IL on December 12, 2008 at 19:50:07:
easy to do. disconnect the internal wire that goes form the ground lug on magneto to internal coil. find a place to mount a coil (many bolt it to hood), run a hot wire through a switch (mag switch will not work) to - side of coil. wire form + side of coil to terminal on side of mag. hot wire from coil to center of cap. You are done. Use the same points and condenser that are in magneto, if they are good.
