Re: 460 gear clash
Posted by CNKS on December 14, 2008 at 09:22:58 from (216.144.104.128):
In Reply to: Re: 460 gear clash posted by Janicholson on December 14, 2008 at 06:40:35:
PTO is disengaged, but it has its own clutch. I can't see inside the clutch housing, need X-ray vision. I don't understand how it would be affected by hydraulics? Inside the clutch housing, the main shaft and possibly the pto shaft do have some movement -- excessive, I don't know. Any vertical/horizontal movement of the main shaft should be cancelled by inserting into the pilot bearing? If I have to split again I will check that out.
