Re: Super C thermosat
Posted by ScottyHOMEy on December 14, 2008 at 12:57:08 from (71.241.208.102):
In Reply to: Super C thermosat posted by ff in mi on December 14, 2008 at 12:11:09:
Heat rises so the hot water would flow that way on its own (like the thermosiphon system in the tractors without t-stats). With a water pump to help things along, it flows in that same direction. Rises as it heats going through the motor. Falls as it cools passing through the radiator. So, yes, it flows out of the top of the motor.
You're in the right place for the t-stat. As I kinda suspected in last night's exchange, it sounds like the clip that holds it in place is missing. You might try CaseIH for part #257441R2 to see if they can get you one. It's an odd-shaped wire retaining ring, and I've only had mine open once, and it was there, so I'm not sure what else to suggest as a replacement. Maybe someone else will have an idea in that regard.
The thermostat should indicate the hot (engine) side on its flange.
