Re: British Diesels attention JimB2
Posted by Hugh MacKay on December 14, 2008 at 15:32:54 from (216.208.58.152):
In Reply to: Re: British Diesels attention JimB2 posted by James Williams on December 14, 2008 at 14:20:54:
Jimmy: The 130 is going to be parted out come spring. Water pump was rebuilt recently and it will fit my thermosyphon SA. 130 has a good Zenith carb, SA has a troublesome Carter carb. Clutch assembly is new on 130, I sence my 140 clutch may need replacing sometime soon. 130 has new front tires, 140 front tires are worn out. The fan assembly and complete hydraulics, I'll add to my personal parts dept.
I may do the same with most of the rest of it, however it will be open to offers on those items. I need a bit more hp and I need live PTO. I think this British diesel should fit. With a bit of fabrication my snow blade will fit 434. Then I can run 2.5' x 8' tarps back each side from grill to fenders, and quit exposing my complate carcass to winter winds on top of 130. Don't get me wrong 130 was a great snow plow tractor, problem is, flesh no longer tolerates cold weather very well, not even in Canada's banna belt.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
