Re: Making battery cables for SH
Posted by r4etired on December 14, 2008 at 15:40:21 from (166.227.116.196):
In Reply to: Making battery cables for SH posted by GeneMO on December 14, 2008 at 15:21:59:
Gene, I have tried the solder on type and found the copper coating is real thin and will work loose. The way I do them is get a good lead battery terminal.bolt type, and solder the copper wire to the lead, then tighten the bolts. I have used them for years that way without a problem. Clem Seivert
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
