Re: regular throtle
Posted by oldiron29 on December 15, 2008 at 03:47:34 from (69.112.219.128):
In Reply to: regular throtle posted by W400 on December 14, 2008 at 22:03:42:
Sir, The Regular had over the hood rod with a spring for tention on throttle. Do you have an F-20 set up on yours with rod on side of gas tank?
If so the clip should be on the front side pushing down to keep grooves from slipping.
Oldiron29
