Re: O.T. Squealing Noise under the Hood
Posted by GordoSD on December 15, 2008 at 13:29:54 from (66.115.200.140):
In Reply to: O.T. Squealing Noise under the Hood posted by Retcol on December 15, 2008 at 13:20:25:
First disconnect the battery ground. Then remove the wires from the alt. Take a picture or make a drawing of where the wires were.
Just remove the bolts for the alternator. Getting the belt off is a snap now. Getting it on is the trick.
When you have the rebuil alt in hand, bolt it back in. Follow the serpentine belt around, you should find a backside idler. That's a spring loaded flwt pulley that tensions up the belt.
Get the belt on all of the pulleys except the alt, then use a pry bar to take the tension off the idler and slip the belt over the alt pulley.
Might need a friend, sometimes you almost run out of hands.
Gordo
