Re: O.T. Squealing Noise under the Hood
Posted by ScottyHOMEy on December 15, 2008 at 14:14:01 from (70.105.224.63):
In Reply to: O.T. Squealing Noise under the Hood posted by Retcol on December 15, 2008 at 13:20:25:
Another one that can squeal is the bearing in the A/C compressor. Try switching your A/C off and on to see if that makes any difference. Keep in mind that your defroster mode uses the compressor, too.
Other than that, the others have it pretty well covered.
