Re: Hard Starting H
Posted by Bob M on December 15, 2008 at 16:05:42 from (74.74.136.142):
In Reply to: Hard Starting H posted by Newtattoobob on December 15, 2008 at 14:55:37:
Is the magneto impulse coupling working? It should make a loud "snap" with each 1/2 revolution of the hand crank.
If the impulse is not working there's no way the engine can be started using the hand crank. Yet it will still pull start easily and run fine.
Frequently simply cleaning and oiling a sticking impulse will get it working again.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
