Re: Hard Starting H
Posted by garytomaszewski on December 15, 2008 at 16:06:29 from (4.158.174.54):
In Reply to: Hard Starting H posted by Newtattoobob on December 15, 2008 at 14:55:37:
Sure sounds like a mag problem(won't start with crank, fires right up when pulled). Is the impulse snapping when cranked? Never can hurt to clean points and rotor and contacts, lube impulse and run her a while to maybe buid up the magnetism in the mag??
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
