I'm with JimN and John T! By tinkering with the current limiting relay inside the voltage regulator you can dramatically increase generator amp output beyond design spec. However operating it this way is a sure recipe for a generator burnout.
Better to replace the generator with a higher output generator or with an alternator.
However before doing suggest you check ALL the wiring in the generator output circuit: generator ARM to regulator GEN, regulator BAT to ammeter, and ammeter to battery. Even a tiny resistance - less than 0.1 ohm - anywhere in this circuit will seriously limit generator output.
FWIW we had an early 60's IHC farm dump that would never charge more than about 15 amps from its 45 amp generator. Replacing generator and regulator made no improvement. Only after removing the instrument panel, discovering an overheated (thus indicating high resistance...) wiring terminal behind the ammeter and replacing it did the problem disappear.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
