Re: Idel Metering Jet Removal
Posted by Slappy on December 16, 2008 at 07:16:56 from (143.88.85.90):
In Reply to: Idel Metering Jet Removal posted by Ryan Edson on December 15, 2008 at 17:58:18:
You probably just broke one or both "ears" off that make the slot you use to screw it out. Dave is right as long as the opening is clean it should run fine. I had my H carb open and found one of the ears broken off. I drilled it out with a tiny bit (don't recall the size) and put the smallest easy out you can get in it. It had a little varnish around the threads but came out fine. I put the new jet back in, and couldn't tell a bit of difference - but I bet I dropped $25 into the drill bit, easy out and new jet.
If the opening isn't buggered up I'd leave it alone. My 2 cents.
