Posted by ScottyHOMEy on December 16, 2008 at 07:38:20 from (70.105.224.63):
In Reply to: Re: H Wiring Diagram posted by Logoet on December 16, 2008 at 06:52:41:
There's no diagram for that that I know of.
Being a half turn out mean that things are set up such that your plugs are firing on the wrong stroke. Two ways, generally, for that to happen. One is simply to have put the right wires in the wrong places. Far more common is to have timed the mag with #1 at top dead center on the exhaust stroke instead of the compression stroke.
Just to make sure you're hooked up right, #1 is the cylinder nearest the front of the tractor, #4 at the rear. Your firing order is 1-3-4-2. So wherever #1 turns out to be on the distributor cap, the wires should run clockwise as you look at the top of the cap in that same order. (The #1 tower on the cap is normally at about 2 o'clock as you look at the cap.)
If they're hooked up in the correct order, a simple check to see if you're 180* out is to swap the wires at the cap. Move each one directly across from where it now is, i.e., swap #1 with #4 and #3 with #2, and see if it will run.
If it does, you have two choices. It will run fine like it is. Or you can re-time it by the book, starting from TDC with #1 at the top of its compression stroke, which will mean moving the wires on the cap back to where they started out.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
