Re: $3800 Farmall M ?
Posted by GordoSD on December 16, 2008 at 08:01:36 from (66.115.200.140):
In Reply to: Re: $3800 Farmall M ? posted by Allan In NE on December 16, 2008 at 07:01:36:
No $700 M's around here. If it's running, no matter how bad the rest is, it's 1200.
I look at the tin, tires, accessories first . Can do a good in frame engine for less than two new rear tires.
Gordo
