Re: 300 starting Problem
Posted by J in Pa on December 16, 2008 at 09:19:10 from (24.239.59.159):
In Reply to: 300 starting Problem posted by Siefring Red Farmer on December 16, 2008 at 08:24:59:
red. i had a similiar problem with an H.
i had the starter off several times and every time i had it tested, they said it was good.
well it tested good on the bench but under a load, it was no good.
if the 300 starter is like the H there are soldered lugs inside the starter and they are easy to miss when checking the starter.
what happens is the lugs get hot and will boil out the lead. to look at it, they look like a good connection, but it isnt.
even in a rebuilt starter the lugs can be overlooked.
well just my thoughts on the matter.
good luck and dont give up.
J in Pa
