Posted by GordoSD on December 16, 2008 at 11:32:05 from (66.115.200.140):
In Reply to: 300 starting Problem posted by Siefring Red Farmer on December 16, 2008 at 08:24:59:
Does that starter have the switch mounted on top of it? Did you replace that switch? If you did your problems may be there. The replacement switches have a much thinner base. If you use the original screws they will protrude through the starter case and keep it from spinning properly. I had that problem. Solved it by putting two small flat washrs on the screws and then installing them.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
