Re: Snowblower Shearbolts
Posted by Jim in Ma. on December 16, 2008 at 11:49:00 from (72.74.1.110):
In Reply to: Snowblower Shearbolts posted by PUTTER on December 16, 2008 at 07:58:02:
I'm not sure about what grade to use but - Something I learned a long time ago, If you run a blower to slow it will sear pins quicker then if you run it at full speed.
