Re: rototiller implement for 1953 Super A
Posted by jdemaris on December 16, 2008 at 14:44:43 from (67.142.130.22):
In Reply to: rototiller implement for 1953 Super A posted by rebecca boucher on December 16, 2008 at 08:57:06:
The only type of tiller that will work decent on that tractor is a self-powered tiller with it's own engine. I used one for years on my Farmal(had an aftermarket 3 point hitch). That way you run the tractor in 1st with the engine almost idling when tilling. Years back, I built my own by mounting a Wisconsin TED 2 cylinder baler engine on top of a PTO tiller and ran it chain-drive. Now, there are many factory made self-powered tillers - made mostly for four-wheeled ATVs pulling them.
If you have hard, rocky ground, a tiller mounted on that tractor will work a lot nicer than a walk-behind Troybuilt.
