Re: rototiller implement for 1953 Super A
Posted by LMack on December 16, 2008 at 14:45:00 from (68.219.78.129):
In Reply to: Re: rototiller implement for 1953 Super A posted by mkirsch on December 16, 2008 at 09:50:35:
The offset in the pto will not cause the implement to vibrate so long as the shaft from the implement is pointed straight forward and level. There will be some vibration in the shaft only which you should not feel because the implement (or super A) pto is offset. Vibration occurs in the immplement when the shaft on the implement is not pointed in the same direction as the one on the power unit (offset or not) such as when turning with a one point pull behind implement even with properly aligned pto's. Manufacturers have been very careful to properly align the end away from the tractor. LMack (Ag Engineer)
