Farmall Tractors Discussion Board
Re: Farmall M - 12 V conversion
Posted by The Red, John Fritz on December 23, 1998 at 11:17:45:
In Reply to: Farmall M - 12 V conversion posted by Brent on December 22, 1998 at 11:31:21:
If you want to keep the traditional look, here is what I did.
I have converted both of my H's to 12 volt positive and the same applies to the M. I found 12 volt generators and regulators that looked exactly like the 6 volt variety.
You do not have to covert the starter. It will just spin faster.
You will need 12 volts light bulbs. NAPA part number 1195 LMP
You will also need to place a resistor in the coil line so you convert 12 volts back to 6 volts. NAPA part ICR 13 ECH
Post a Followup
: Re: Re: Farmall M - 12 V conversion
