Re: Govenor question
Posted by Greg-N-CA on December 17, 2008 at 05:45:09 from (66.81.216.86):
In Reply to: Govenor question posted by Ron Valentine on December 17, 2008 at 03:54:13:
It is straight forward and it will need more than just cleaning. I went completely through my governor, replacing pins, bushings, bearings, bumpers, plugs, gaskets, springs, etc. Check your manual for setting the timing marks and pull the gear so you can replace the parts on it too. For a list of parts you'll need, go to: https://webparts.pvassociates.net/cnh/webparts/main.php
The governor has a tendency to build up moisture and the parts will rust over time. I made a bushing removal tool and replaced the bushing/bearing in the block too. Good luck and have fun! Greg
