Re: 300 starting Problem
Posted by Siefring Red Farmer on December 17, 2008 at 09:34:13 from (12.37.116.130):
In Reply to: Re: 300 starting Problem posted by boomer22 on December 17, 2008 at 09:23:56:
I used crimp on connections, no soldering. However, I have soldered on ends before with a propane torch. Direct the heat onto the connection, keep it off the wire. Eventually it will get hot enough to solder properly. When I am done, I use a piece of heat shrink tubing, use the torch to shrink it, to cover the joint. This tubing can be purchased at NAPA or most any automotive store.
